Help Identify the year - Yamaha IT 175
Arsist
5
Frame code is 3R6-004622
From the searching I did, it seems to be a 1976. However, it doesn't appear to be listed on the yamaha page. Would like some help identifying the year so I can see what engine/electrical parts are interchangeable with other years. Mainly the CDI and such.
thanks
Arsist
5
now to get it running.....hehe. Should be interesting. The electrical was all removed so I need to find the ignition system.
Would you happen to know what year of CDI and coils are interchangeable?
thanks
Arsist
5
thanks.....it's right side drive. Thanks for clearing up the parts for me. Wasn't sure if the 82-83 electrics would work. Should help in finding parts.
Arsist
5
thanks for the links.....will help a ton.
another question.....found a 1980 IT125 for dirt cheap, would much of it transfer over?
Jan 3, 2007
1,860
Arsist, yes. The pipe will not but the engine should bolt right in. The chassie parts are also the same. If the engine is running you should take out your engine and give the 125 a chance. It produces better bottom end with less top hit.
