guts said:hate hear that happend ! i would drain oil in crank case look for metal shaveings, or water in the oil, it will look milky if water in there ! next step get a book, they come in handy . if it's the topend you can redo it your self not hard at all . after you pull topend see if the motor turns over bye hand should turn free , if it don't turn over there is the problem ! but if it does turn over it was topend . goodluck let us know what find out !
adam728 said:There is no oil in the crankcase of a 2 stroke. The oil is only in the transmission/clutch area.
I would start by pulling the head and cylinder and checking things out, like everyone else said.
guts said:no disrespect ! but if you didn't put oil in the crank case then you tranny or clutch would not be running in it either 2 cycle or 4 cycle !
adam728 said:I think we are looking at it differently. There is oil in the tranny, yes. But in the lower end of the engine there is no oil on a 2 stroke. The crank bearings and lower rod bearing are lubed by the oil in the premix, not the oil you put in the transmission.
