Hi,
Just bought a 96 RM250 - guy said it has no spark.
Can you tell me the best place to start.
Any good links to UK / Irish parts suppliers.
Dying to get it going need as much advice as poss.
I would start by checking for spark myself. If there is indeed no spark then get an ohmmeter and check all the wires associated with the ignition. I had a wire break inside of the insulation one time and it took me forever to figure that one out. If everything checks out then head to the dealer to see if you can get specs for testing the stator.
It seems the ignition coil is knackered, do i need a special tool to remove the fly wheel?
Or will a couple of screwdrivers behind it work?
Can you give me a pointer to where i may buy the flywheel puller(if req).
