markkdx220
- Jun 2, 2005
- 4
- 0
The weirdest thing just happened and I need some advise.I just pulled the bike out of storage and did all the routine maintanance.(change oil,clean carb,fresh gas,new plug.Well I started the bike and it was bogging so I was trying to warm it up so to see if it would clean itself out .after about 4 minutes I decided to adjust the idle and air screw to see if it would help and had no luck.So this is where it gets weird I was reving the bike and then letting it idle and all of a sudden the revs went to about 8k and I didnt have my hand on the throttle.I panicked then hit the kill switch and nothing happened.I grabbed a screwdriver and pulled the spark wire off the plug and it was still screaming ?? Next I tried to pull some wires apart and got shocked and fell to the ground.Next I pulled the gas line off and of course it was still screaming.Then I removed the idle and air screws and it didnt help.I finally pulled the carb slide out of the carb and it finally stalled.What the heck is going on.This is the one of the strangest thing thats ever happen to me.It should of died when I pulled the plug wire off.Any help would be apreciated.As of now IM afraid to even start it.Thanks in advance
