jmics19067 said:I Is it feasible to run your fitting and tubing straight out of the fork with less bulkiness/restriction and then put a larger valve/fitting at the handlebar. Is their room for more flow by just having a straight hose barb out of the fork and then a larger valve/ fitting at the bars??
marcusgunby said:so overall the thoery is good :fft: but i need to drill the caps and use larger tubing and valve.
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
