Check out Carb tunning in the tech section by Canada Dave.
It's all there.Read the table for elevation temp.
You will be able to work out the corection factor.
I have a brand new 2002 KDX 200 and I live in Fountain Colorado. I lowered my main from the stock 160 down to 148 and the stock pilot 48 down to 45. The only other thing I changed was on the needle and I went to the 2nd notch from the top. It runs great.
Go to CDave's website.
Click on <tech tips> and then <carb tuning>
There is a graph in the subsequent write-up that has a chart that will show you what factor to use to arrive at a correct jet for a given altitude change. Not altitude, but altitude CHANGE...so it will work for anyone regardless of where they are and where they are going to.
'99 included.
kdx fer sure.
220? Yep.
Even in colorado!!! ;)
