How do I test my compression, 250 2 Stroke???
snb73
770
I have a 2003 RM-250 and I want to test my compression. What is the proper methode for testing compression on a 250 2 stroke? How many kicks for an accurate reading?
Thanks, Steve.
kawicam125
Uhhh...
Mar 14, 2006
195
go out and buy a compression tester. next, remove the spark plug and insert( screw in) the tester into the spark plug hole in the cylinder. don't try to start the bike, just kick it until the reading on the tester won't go any higher.
darringer
1,029
Also, push the kill switch while kicking. Warm or cold will vary only slightly. It usually will take quite a few solid kicks for it to top out.
Masterphil
DRN's Resident Lunatic
1,003
Do a compression test when you get done riding the bike. That way you know it will be warm. When I tested my 125sx I got 170 cold, but 195 hot. There is a big difference.
Procedure to do a compression test:
Pull plug
Screw in compression tester
Open throttle all the way
kick until the meter won't go any higher
Your bike should be in the 190+ range, and I wouldn't be suprised if it is over 200.
snb73
770
I was riding in some very fine dirt this weekend and the motor sounded different. I lost some top end and over rev. I changed the plug and that helped, everything was back to normal. Then I took the bike around a small track, just putting around. The same thing happened. I will change the plug, but wondered itf some silt got past the air filter.
I wasn't sure how many kicks it took to get a valid reading. I have 220 lbs after about 10 kicks, it went down to 190 after 24 hours. Guess the rings are good.
Thanks, Steve
Masterphil
1,003
Saftey first!
The downside to a compression test is that it only tells you how well the piston/rings are sealing. It gives you no idea how much the piston is rocking in the bore, or how close the piston is to a stress fracture.
kshackleton
109
gillsm said:
Why do you guys say you should push in the kill switch,just curious. thanks
There is a small chance of damaging the coil without a plug installed...that is the only reason that I can see to hold down the kill switch.
