Blaise22 said:how can you tell if its running too lean?
Blaise22 said:Thanks for the advice Ill try that :nod: About how many turns do you turn the idle screw up?
2strokerfun said:Warm it up. Then stop and put a new spark plug in it, open it up with a load on it (like going up a hill), pull in the clutch and hit the kill switch. Now check the plug before running it again. If it's white or slightly off white, you are too lean.
Rich Rohrich said:Four-stroke plugs are ALWAYS white when they are jetted correctly. There is no oil burning in the chamber so there are no oil deposits on the plug to color the insulator.
Unless you have a ton of experience, trying to jet a four-stroke by reading plugs is really difficult.
Blaise22 said:Do you have a special way of tuning a four stroke :) ?
Does the idle screw have an effect on the engines performance?
Rich Rohrich said:Assuming you exhaust system isn't leaking anywhere and drawing in fresh air that causes a re-fire, when the low speed jetting is correct it should backfire a little bit when you decel hard from high rpm. If it bothers you, as was pointed out in one of the posts above, richening up the low jetting with the fuel screw or the pilot jet will eliminate the backfire, but usually at the expense of some throttle response.
It's been my experience that people run the low speed jetting too rich to eliminate the backfire, and then spend countless hours (and usually $$) jerking around with the accelerator pump trying to get the throttle response back.
It's a system, and making a change in one area will have usually consequences in others. So working carefully making one change at a time and documenting what the results are across the board will generally give you the best results as you are learning this stuff.
