I adjust my air pressure whenever I change from soft terrain to roccky terrain
My jetting, maybe once a year
My suspension stays were it's at
Wheel bearings get greased anytime I take the wheel off
Same as Zero, except I set tire pressure at 10psi before every ride. Here you go from rocks to sand and back again in 50 yards. If you changed pressure for different terrain, you'd never get to ride.
Tires before every ride, pressure varies depending on condition. Blead air from forks before every ride and between rides.
Jetting, when it needs it - typically seasonal and whenever altituted is going to change more than 1500ft.
Suspension - whenever expected riding conditions dictate. For example, I will run different settings for the budd's creek harescramble than for the clifside harescramble.
