Timr
- Jul 26, 1999
- 1,972
- 6
Open these two links in additional windows then feel free to participate in this discussion.
http://sera.dirtrider.net/Images/Roll1.jpg
http://sera.dirtrider.net/Images/Roll2.jpg
Note: these are fairly large image files. High speed conection is advised. If you have low speed conection, have patience, download the images and save them to your hard drive so you can refer to them as this thread grows.
I’m trying to accomplish two things with this thread:
1. Help new enduro riders understand how to interpret the information that they receive at a race
2. Get some feedback from other enduro racers about how the roll/Jart chart and route sheets vary from region to region and series to series.
Ok, first let me qualify myself. I am by no means an expert on timekeeping or enduro racing. I’ve been racing enduros consistently since the ’94 season. I’m currently a mid-pack “B” rider. I usually finish anywhere from 3rd-7th in 200B, and about 17th-25th in Overall B. This in not the gospel of “Time Keeping” according to TimR, so please chime in and add your .02 cents worth.
The two above links are a “roll chart” that I purchased for $2 bucks at the sign up of the Meridian SERA enduro about 4 months ago. I remember when I was loading my roll chart holder at the Gulfport race, that I thought it would be fun to post a roll chart on DRN for a discussion, so I threw the roll of paper in my gear bag instead of tossing it into the trash. I finally got around to getting it scanned in so we can now discuss it.
So, what happens at the start of an enduro? Well, you roll up to the start line where they are counting down and starting the rows on each minute. You’ve either already set your clocks/computers to key time, or you are waiting to set a countdown on your clock/computer based on what’s happening at the start.
The start of and Enduro is a Known Control (KC). Therefore, there cannot be a secret check for 3 miles. There’s an AMA rule that states that a mile marker must be posted at the 2.9 mile mark for the purposes of checking the race mileage versus your own odometer.
If you’re looking at the first page that I posted, you’ll notice that the roll chart is layed out in long strips. Originally, I cut them and taped it into one long stip and then loaded it into my roll chart holder. I taped it back together in 8x10 mode so it would be easier to scan into the computer.
The format of the roll chart that we use is mileage on the left, and time on the right. Notice that the time on the right is based on Key time. This is why you should set your watch to be key time when your row leaves. Example: If keytime is 8:00am, and you’re on row 20 then your digital wrist watch should say 8:00am at 8:20am. I hope that makes sense.
Now, you’ll notice big Xs between the mileage after the start. This signals that these aren’t “possibles” or locations where a check can be because of the no check for 3 miles rule. Everything good so far? The next thing that you’ll notice is that almost immediately, there’s a reset at mile 2.5.
Why would the club do this? Surely, no one is tired after only 2.5 miles of trail at 18 mph. The reason that the club probably did this was to be able to put the first check where they wanted it. What this means is, they didn’t have over 3 miles of trail from the camp to the desired location of the first check. So, to get around this, they put a reset in to advance the mileage so they could put the check where the wanted to. I just so happens, that this enduro was held in a motorcycle park that was only 1000 acres big. BTW, the club did an excellent job laying out this race with the little amount of land that they had to work with.
So, in this race, there was no 2.9 mile marker, but it didn’t matter, because the posted mileage at the first reset allowed everyone to make sure that they had their odos/computers set to the proper mileage.
Turns out at this race, if I can remember correctly, that the first 2.5 miles to that reset was some very tight virgin trail, as a result, we only had about a minute at the first reset before it was time to leave.
Now, look at what happens after the first reset. There are possibles from 3.3 to 7.5. That’s 4.2 miles total for that section before the next reset. This may be a test section. At 18 mph, it’s hard to tell. It depends on how hard the terrain is. So, the club may have one, two or zero checks in this 4.2 mile stretch. If they have two checks, then the first check would have to be at: 3.3, 3.6, 3.9, 4.2, or 4.5. Why? Because if they put the check anywhere after 4.5, there’s not enough mileage left for them fit the second check in. You see, 4.5 + 3 miles is 7.5 (which happens to be the last possible before the reset). So if there’s going to be two checks, then more than likely, it will be at 3.3 or 3.6. If it’s at 3.3, then the rider must be careful. That’s the first possible after the reset, and if you leave the reset early “hot” then you might burn the check.
If there’s only one check in the section then it could be at any of the possibles. More than likely, it would be in the middle to the end of the section. If it was at the end of the section, and the terrain was really tight, leaving the reset early and riding “hot” would pay off in this situation.
Questions so far??? Comments?? I’ll update this thread with another analysis of the next section. Or, if someone would like to give their own interpretation then feel free. I know that there’s a couple of guys on this board who rode this race. However, it was so long ago, that I can’t remember where the checks actually were. That’s no big deal here though since our goal is to figure out what we can learn before the race when we’re preparing our computers and equipment for the ride.
One thing that seasoned enduro riders will admit is that each club has the way that they like to do it. So, if you’ve ridden a certain club’s event a bunch of times in a row, you’ll get a feel for how they like to lay out the race. You’ll have a better chance of guessing correctly on check placement.
:D
:D
