Hey guys my clutch cable frayed out, so I got a new OEM one... I know I need to pull the stator cover off, but what entails behind that to connect the cable? Thanks for tips, tricks, or advice! :cool:
There's nothing behind the cover to scare you. The cable is connected to the clutch arm ander the cover. It has a "barrel" style zinc end on it. dissconnect the cable at the lever so you'll have enough slack, pull the inner cable out enough so that you can align it with the slot in the clutch arm, and just pull it out of the arm. The cable houseing is just held in place with an O-ring, it will just pull out of the hole that it is mounted in. Feed your new cable back through the bike in the same location that the old one was. Re-connect both ends and set your free play. Then put your helmet on and go for a BRAAAAAAAAP !!!! :ride:
