Rear hub on my KX is wobbly after replacing the wheel bearings and using bearing sleeve retainer to take up the ~.005" clearance between the bearing OD and bore. I'll probably try it again but I'm wondering if anybody has had a shop bore the hub oversize and install a steel sleeve instead of replacing the hub? Any recommedations?
Thanks,
Brian
Thanks,
Brian
