I'm playing with jetting on my recently overbored 98KX250. As I understand fuel signal, it's the ability of the motor to pull (vacuum) fuel into the combustion chamber. Therefore, an overbore kit should increase the fuel signal, based off the fact that lung capacity has been increased. Further rationalization would lead me to believe that an overbore kit will require leaner jetting, because the motor is breathing in more fuel per stroke than before. With all this said, most posts I read regarding jetting of overbores indicate a need for fatter jetting, which is contrary to the reasoning above. Any feedback would be appreciated.
