- Apr 22, 2007
- 84
- 0
Ok, I have a 01 KX 125 fouling plugs fairly regularly. I am a novice rider so I suspect i am not pushing the bike hard enough to get the plug (BR9EG) into its heat range to burn off the deposits. I am about to change to BR8EG until i get a bit more confident with the bike (my first bike of any description) and feel confident with keeping it in the powerband (I am assuming that the powerband is where you open the throttle and the revs go high, higher then all of a sudden its HOLY SH1T!!!!! try to hang on!) The question I have is this: The bike is totally standard factory built spec - why would i need to play around with jetting, i am assuming it worked ok coming from the factory!, Now fair enough, wear and tear is expected on a six year old bike, but shouldn't a good tune up (repack exhaust, clean air filter, flush tank etc sort out any problem). Also changes in elevation is not an issue in this country per se.
Any thoughts are appreciated! :cool:
