Hi there,
I have an '01 KDX200. I have idle issues with the bike. THe idle screw is all the way in, air screw can be anywhere from 1 to 2 or even 3 turns out and makes no difference to idle speed. I opened up the carb and it has needle R1174K centre clip position with main jet #160 slow jet is #60. It has an FMF knarley with powercore II on.
When running anywhere above 1/4 throttle it has great power, but it struggles to idle and there is no hit off the bottom.
Normal altitude is around 1400m (4200ft) temperature is 18-28'C
I know this jetting is way off what everyone else is saying but thats how I got it? I run 40:1 motul syn oil.
THe bike is quite heavy on fuel and has quite a bit of spooge. I repacked the silencer a month ago. I have no problems with plugs fouling.
Suggestions? Could it be compression related? Where do I start? Thanks
