I have the following specs:
175 Main
40 Slide
AS 1 out
52 Pilot
Clip 3 position
98 Octanes gas at 32:1
Castrol TTS oil
No spooge, my pilot is ok(I have great response and the idle is perfect) in 1/2 throttle opening the engine has strong power and at wide open no problems (the reading plug is perfect, gray color with a black ring close the bottom of insulator).
But I am not satisfied yet. If I am riding for 1 minute more slowly and then crack the throttle from 1/8 to 1/2 I can see a little of smoke but without any surging or hesitation!!!!
How can I clear up this smoke ? Could be a solution changing the needle taper a step more leaner ? it will affects about from 1/8 to 3/4...
Any help would be nice.
175 Main
40 Slide
AS 1 out
52 Pilot
Clip 3 position
Castrol TTS oil
