I want to know what i should jet my 2003 kx 125 to. I have never had a good looking plug come out of it. It always is a very dark chocolate or has carbon on the insulator. I am using a b8es plug and the jetting is 420 main, 40 pilot, needle 1st position, air screw 2.5-3 turns out. The altitude is around 1000-1500, 70-90 degrees, and humid(i live in missouri). The bike seems to load up quick. I was thinking of going to a 37.5 pilot, needle 2nd position and a 410 main. I am a novice rider and am pretty slow at the track. Even when i ride in a field the plug does not look great. When i went to the track last time, i used a 7 plug and it even came out on the dark side. I am very scared of siezing my engine or running it too lean and causing damage. I run yamalube 2R at 40:1 with 91 octane pump gas. would it be safe for me to change the jetting to what i listed above. If not, then please reccomend jetting that i could change to and reassure me that i will not sieze my engine.
