Jetting Question..Going to Glamis...
jsyi
Will I need to reject if Im going to Glamis? I believe the Elevation here is around 2,500 ft above sea level...and the elevation at Glamis is around 50 ft below seal level.... Thanks.
CspineRider
156
I have a 97 CR250 as well, and I run a 178 main in Glamis and a stock pilot/slow. When are you going? If it still in the high 80's when you go, you could get away with the stock 175. But if your going in the cooler months, go with the 178 main. Mix at 32:1 as well to be on the safe side. This is if you have a stock cylinder. Any other questions feel free to ask. I go to Glamis all the time and my bike screams there.
