yz250roost
- Oct 16, 2000
- 534
- 0
Hey guys,
Sorry for another jetting post but here it goes. While out at the desert this weekend I found that my PC platinum pipe was turning somewhat yellowish on the header part, the bike was dripping a small bit from the overflow onto the pipe, but that part is only a small area, the whole header where it makes the u turn back the other way is turned a tarnished yellow color, this led me to believe that I was running lean, causing excessive heating of the pipe and turning the color, but the thing is I'm getting excess spooge between the pipe/silencer, what in the world is going on here. could it be too rich of pilot jet and too lean needle, I'm getting frustrated, just when you think you have things figured out......thanks in advance...by the way make sure that your main jet is tightened when you put it back in the carb...learned the hard way.
Jeff
Jeff
