I picked up an old JR50 for my daughter last year. I went thru the top end and carb. It didn't run too bad, but never wanted to start after it was ridden for a while. I found a good deal on a newer engine and carb this spring so I put that in. It starts real good but just kind of bogs out when you put a load on it. I changed sprockets so I am running 12/35 front/rear. If you baby it along you can get it going fairly well
My question is, am I expecting too much out of this little engine? My daughter is a little over 90 lbs. She is scared of the XR50 so I wanted to keep her on the JR for a while. Do any of you Dad's out there ride a JR, will it pull you OK?
