So, I want to follow the break in instuctions.
Says to let it idle for 15 minutes then shut off.
Problem is it won't hold idle unless I give it a little throttle? Is that normal on a new bike?
It also makes a small cloud of smoke, but I think that is normal with the 2 strokes. I have owned all four stokes for the last 12 years, and I can't remeber how much smoke is normal.
So, is it normal for the new engine to not hold idle? If so, fine. If not which way do I turn the idle screw to speed up idle? Clockwise right? I turned it in about 3.5 turns so far with no effect.
Thanks,
Phil
Thanks,
Phil
