Well it is just too cold to do anything else - so I decided one more winter project would pass the time.
Last night I thought I had won a set of XR springs on Ebay - but someone outbid me at the last second (probably a fellow JustKDXer).
Anyway - I found the OEM springs new for $76 a pair - and from all the chatter and threads - they seem to be the way to go. Should be here by the weekend.
Trying to summarize the 100 threads on the forks seems to come to a consesus that the space from top of the spring to the cap is about 2-4 mm. To get about 10mm compression (seems to be the center of consensus) I would need a spacer of 12-14mm. Seems to make sense.
While off - will change the fork oil. Measured collapsed with no springs - this runs the gammit from 95 to 120 mm - with many folks stating 100 is ideal.
So in summary - I plan on using 13mm spacer (about 11mm compression). Mobil 1 ATF at 110 mm from the top.
Seems to be right down the middle of all the threads. Anyone running this identical setup on their 200?
sn
sn
