How can you tell the difference between a KDX 200 and a KDX 220. And how can you tell the year. Just bought a bike and cant tell what cc or year. Can someone help !!!!!
Yes, its cast into the cylinder. 1996+ KDX's were all the same other than color. A dealer can tell the year from the VIN number (located on the steering head).
Thanks for the great feedback guys. I'll try and post a picture to see if that helps any. I saw DX220 marked on the exhaust pipe but not sure if that means anything. I checked out the BUYKAWASAKI site and it said that the engine number should be marked on the lefthand side near the crank case below....so i'll check that out too...
Can you post the vin first 11 digits in the vin? I can tell you what year it is. :nod: :cool: also sometimes the model is stamped on the front of the reed valve boot. should say dx200 or dx220? also stamped under the gear shifter on the engine. :nod:
Bike reads DX200 on crankshaft near the shift lever. One side of the neck has a japanese sticker on it that I cant make out at all except for II DX200 and the side were the VIN is marked is completely non readable. Would a KMX have a DX markings on the engine or on the chasis....I'm not sure. The bike has a speedo, light switch, horn and on/off button with the key fitting right under the riders left hand leg ???? Looked at different pictures and looks like a '94 because of how the tank and radiator covers are fitted on...still unsure !!!!
Sorry to keep hounding you guys but all the help is appreciated...checked the crankcase again today the number is KHI DX200 and below it it read GE 004531. The neck of the bike read DX200G and below that II 157. The rear swing arm has UNITRAK on it and the frame is tubular. Thanks again.
When the mfg. scribes this on a pipe , keep in mind they are Japanese and their customs are quite different than other parts of the world, it generally means dont buy me unless you know what year and size I am.
Too late already bought ! I agree with Lepper must be a '94 DX200SR grey market Japanese bike. Would parts of a regular '94 DX200 fit on it e.g rt. side crank cover, carb., pistons ...etc.
