andy jackson
- Jul 8, 2002
- 12
- 0
where do u ,when measuring sag,measure to?ive measured from rear axle 2 rear guard.Is this correct or should i measure from axle 2 some where else?At the moment it measures 75mm,how much difference will giong 2 100mm make?Also the rebound & compresion dampering adjustment,should yhey be matched?eg 13 clicks out four both or does it matter if they r different?eg 13 compression & 15 rebound?cheers 4 advice.
