Ordered 0.44 springs today for my 250sr, the seals started to leak after three years of running between 15 and 25psi with standard 0.29 springs :yikes: , always having positive pressure in the legs probably helped the seals resist packing with dirt.
If the sr comp' valves are the same as the U.S model I'll remove some high speed shims.
Just wondering if I should use a heavier oil for more rebound, currently using 5W and feel it could use more rebound damping.
