Is is possible for the kips to be put bvack together so that the main and subports are out of phase? currently, when the kips shaft (behind LH cover) is at 12 oclock (< 6K rpm ?-please confirm):
subports are 50% open
main port is low (smaller)
resonator is closed
turning the shaft counterclockwise to ~ 10 oclock (> 6K rpm ?) yields:
subports closed
main port high (bigger)
resonator open.
This has to be wrong - please confirm that this is a) possible b) indeed incorrect and c) what to do to fix it.
also when returning to 12 oclock (closed/below 6Krpm,) it does not go all the way back, but stops on its own at about 11:30.
history
bought a 97 220 - ran like crap on top - just hit a wall. I suspected kips clogged so had it looked into. recommended top end I concurred after inspection (originial piston)
broke it in still runs weak on top. Got the RB carb done not expecting it to fix that but still it just won't rev out at all! was considering rev pipe (gnarly on now).
Please tell me whether I am on target with the conclusion the KIPS is out of phase. :coocoo:
resonator is closed
subports closed
resonator open.
history
