KLX_BOY
52
Hi everyone,
iS there a technique to kick a 94 Kawasaki KLX 250 over.
I really stuggle to kick it off.
My dad can kick it over(sometimes) but that is because he has alot of muscle and he still struggles himself.
And i am 15 so i need to know so i dont get laughed at.
sometimes it kicks over cold, but when it is hot you have no chance, you have to bump it off.
When you kick it you have to keep on doing it not 1 not 2 not 3 not4 not5 times you keep on doing it until you run out of breath or the bike kicks off (rarely).
Somebody must help me please.
Thanx KLX_BOY.:(
RM80kid
53
My dad and I both have KLX300's. A '97 and '99. I am 12 and can kick mine over in one or two kicks hot or cold. First check your fuel mixture screw. Try turning it out 1 1/2 turns. The manual says 2 1/4 but this is too rich. Next try this technique. Slowly push down the kick lever until you feel top dead center (it will get hard). Now slowly bump down the lever until you feel it slip down into a notch. Now release the lever ALL THE WAY to the top and kick it down like you are trying to drive it thru the ground. You have to give it all the power you have, you can't kick it like a 2 stroke. This works every time for us. If you just try to kick it from anywhere in the stroke it will not start. I am 5'7" tall and weigh 185 lbs. so I have a lot of strenght to kick it with, but it just takes practice. You can e-mail me at boarderboy101@cs.com and I will give you my phone number so you can call me and I can explain it better. The bikes are great so don't give up.
Chris
KLX_BOY
52
Thanx Chris,
Just for the info i am 5'10 and 172lbs. When i kick it top dead centre it will kick off only sometimes.
I also would like to ask you is there any UK sites where i could by a KLX exhaust system.
Thanx for your help it is appreciated.
KLX_BOY.
ride_red_15
Uhhh...
Oct 14, 2001
574
slowly kick the kick starter until you feel strong resistance ( 4 strokes makle power on the 4th, hence the resistance) and kick it hard then. always worked for my XR400
FRESH VIDEO
