jaguar
Mine is only 9.5 volts and since the bulbs are 12v and someone on this forum said the voltage should be 12 volts I replaced the regulator with a "Volt Pack" from MX South. In about 1.5 seconds it blew my halogen lamp. !@#$%
When looking at the original regulator it does say "9.5" on the second line.
Has anyone with a good digital voltmeter measured the output? (I measured mine at the turn signals using the "hold" setting which captures the peak reading.)
