kx 60 carb overflow problems... help
sam2007
16
every time i lean the bike my over on the throttle side even just a bit of lean ,gas starts from the bottom overflow vent hose the one at the float bowl float level is at 20.5 mm in spec, and bike runs good other than on and off bog-trys to die on me in the corners sometime [float needle and brass thing it goes in] to are super clean look like new someone have any idea whats up with this
Joe450
4
Needle and Seat
Yeah, it sounds like the needle and seat is bad, I just replaced it on my yz80, it had the same problem. To test it take the carb off, drain the gas from it and take the float bowl off. Blow as hard as you can throgh the gas line that goes from the carb to the gas tank while holding the floats up with your finger. What this will tell you is if the needle valve is shutting off the gas or not. If you feel any air passing by the needle when you blow and are holding the floats up, it means that gas can get by the needle which will force the needle open and will not shut the gas off causing the float bowl to flood and make gas pour out the overflow line. The floats could also have gas in them, which would cause a similar problem, take the float of and skake it to see if there is any gas inside them, if there is gas inside replace the float. O yeah a needle and seat will cost $27.55 from bikebandit, good luck!
sam2007
16
thanks to all great advice from all, here is some more information for ya all, i did find that the float neddle and seat were not doing there job not sealing, and did the rubbing compound trick and rotated the float needle with tweasers from my swiss army knife...lol 10 min later just like new no overflow problems....saved myself 40 dollors the local parts house wanted for the stuff
