dirtbikr99
- Nov 21, 2002
- 180
- 0
I have a kx 80. I tore it down because it was old. I replaced the piston and rings with weisco, stock bore. While I was in there I did some porting. Just some to the exhuast mostly. The nikasil looked good. Put it all back together and it was cutting out on top end. It would start right up then not rev out. I changed the plug and it would rev out again and be good. Then work then not work.
The plug looks ok, more on the rich side. Because of the porting is it now needed to lean out the jetting? I noticed pro circuit used a 122 instead of a 125 main jet.
Any thoughts?
Any thoughts?
