dirt track killa
- Jun 6, 2006
- 29
- 0
my sons 03 kx 85 has a stumble from idle to WOT,I have tried lowering the clip,raising the clip,in and out on air fuel,tried different ratios for premix,and I can not get this thing to pick up.Any suggestions?
edit:if you roll on slowly it will pick up fine,the engine picks up a different note when he whacks the throttle fast,instead of screaming,it sounds like its running out of breath.this is stock jetting,the clip is currently 1 up from middle,air screw is 1.75 turns out
