JohnF said:
ok, mr. expert, then tell me what are the proper size jets and float level i need to have and i will tune the carb accordingly. ive asked that question bout 5 times now, but i guess no one knows? where could i find that info?
One reason nobody has told you is there are way to many variables for me to tell you what to put in. Temperature, elevation, fuel, and any modifications to the bike all will vary what you will need. Someone gave you the good advice of pulling the jets you have in there and buying one of each bigger and smaller to see which way you need to go. Get a manual for your bike and look up the jetting tables (at least the Yamaha ones have the tables).
You have done a pretty good job of describing the problem but no one over the internet can really make an exact repair recommendation without some crucial data such as what is your compression for real, what jets are in there now, what is the clip position on the needle.......
So far everyone is making educated (for the most part) guesses on limited info
