My 9 year old just started riding a 2006 KX65 this year. He weighs about 75 pounds. I set the suspension to the Team Green specs which are as follows:
Stock springs front and rear
1.5 turns out on the rear shock
Sag of 70mm
2 turns out on the front forks
10mm on front fork above the triple clamps
Just pushing on the bike in the garage, it feels unbalanced - the rear feels too soft while the front feels stiffer. On the track, this same holds true. The rear bottoms and tends to kick and swap around. Off of jumps, it has a tendency to be nose low (i.e. rear kicking up). In addition, he does lose the front end from time to time even though he is usually right up on the tank.
I just can't figure out how to stiffen up the rear to match the front and keep the sag the same. Stiffer rear spring? Also, there just doesn't seem to be too many adjustments that can be made with clickers so does anybody have any setup tips? Also, my son is fairly tall so I don't want to raise the forks 5mm to make the front end stick.
Sag of 70mm
