jtimpano108
- May 31, 2018
- 7
- 1
Looking for some tips I’m pretty new to 2 strokes...I just picked up a 97 rm125 for a steal but it was a mess no power no power band the power valves didn’t work the bike ran extremely rich and bogged it would idle or start without 1/4 throttle after lots of looking on forums and such I figured out a lot of good stuff first thing was fixed the power valves so my first question is with the adjustment on the power valves will more spring tension cause more low end power or will it give a later power band? Currently the bike runs a lot better it will start first kick and idle with no throttle input it revs up nice without bogging after I rejected the carb (170 main, 50 pilot 2nd clip position) these are recommended by pro circuit for their exhausts which is what’s on the bike now the bike has power won’t bog out at top end throttle but it seems to hit the power band a little late and also seems to be lacking power in the low end in first at full throttle the bike won’t lift the front tire off the ground I’m thinking the bike is still a bit rich? As I lean the bike out using the air screw it runs better it’s currently 4 turns out which means leaner jets I guess? Which jet should I bump down and what jet would be causing lack of low end power as I leaned the bike out with the Air screw it seemed to get a bit more power and eliminated the pop and bog at full throttle...any input would be appreciated thanks everyone
