An annoying bog/cough has reared up recently - happens in the first 1/8 to 1/4 throttle, but only at low engine speed. If its winding down with the throttle closed & I snap it open - no hesitation, just zoom zoom. It seems to have gotten just a bit worse since I removed the snorkle.
The air screw seems to have no affect on this problem - have tried from 2 1/2 down to 3/4 with no real fix, although the richer setting seems marginally better. Just got done taking the float bowl off & inspecting. All seems clean, float level just at the parting line where it has always been.
This problem is usually associated with a lean/flat spot, right? Yet the weather has been getting 'richer' in recent weeks, if anything. And I did not have this lag a few weeks ago.
Is this more of a pilot/air screw problem, or needle position? Need an idea on where to start chasing this down.
The patient:
box stock 2002 200, BR8ES (original plug), 32:1 w/ 93 oct, 155/45/1174K @ #2.
The patient:
