little jeff
- Aug 20, 2002
- 126
- 0
This message is actually directed to Eric Gorr. This Fall sometime, I will be sending you my top end off my 2002 KTM 300EXC for your porting job, head mods, and machining the bottom of the cylinder. My question is this, when you machine the bottom of the cylinder, will the shaft from the crankcase that actuates the power valves, still be able to engage the gears on the power valve? I hope I worded that correctly. I haven't taken the cover off yet to see how that is set up yet.
Any thoghts
thanks little jeff
Any thoghts
thanks little jeff
