Ok, go easy as I'm completly new to bikes!
Just brought a 1999 Yam Wr 125 - very nice and in good condition. Brought some oil (from the MX shop - can't remember of the top of my head what make). Mixed it up as per instructions (50:1) when out riding for the first time on the bike (2hrs). When I got back looked at the back of the bike (and my cloths) and there's black splooge/oil everywhere around the exhaust (a lot).
Ok, the previous owner hadn't used the bike in the last 8 months or so (he tells me). Di you guys think I completly messed up mixing the fuel? - I used a 10litre canister which I filled up at the garage,a dn then using the guide marks on the side of the bottle poured the oil in. I presume that the splooge coming out of the exhaust is either 1) I messed up the fuel/oil ratio and put way too much oil in or 2) because the bieks not been used for a long time its having a 'bit of clean out'? What do you think.
Also is it damaging the engine i.e.clogging it all up - so I need to clean all the splooge out?
What should I do? - should I make sure I'm mixing the correct ratio (get a large accurate meassuring jug) or prehaps make a leaner (i.e 1.5% mix) until it stops splooging?
Help I have no idea :silly:
thanks
thanks
