Vic
***** freak.
4,008
I've heard that there are programs that will effectively move your mouse at some predetermined interval to fool your ISP so you don't get disconnected if you leave your computer for a while. Does anyone know where I can get one?
Okiewan
Admin
2,238
Texas
Wont having your email program check every 10 mins or so keep the connection alive?
there are keep alive scripts out there. Try download.com ?
B
biglou
I may not even be in the right ballpark here, but at home (dial-up) there is a box to select how long to let your pc sit idle before disconnecting. You can choose "Never" in that window. I think it reads "Disconnect after _______ if idle"
If you guys are talking about some serious programming stuff, I'll shut up and go back to my corner.:)
Vic
***** freak.
4,008
That won't work with the ISP I'm using.:(
I tried an e-mail checker program that I found at download .com, but it didn't do the trick. I like the program, otherwise. I found a few other gems while I was there.
I did a Google search and found what I was looking for.
Thanks, guys.
