riderdadof4
- Dec 30, 2005
- 32
- 0
1. 98 kx 60: connecting rod play at crank, crank discolored, piston scored, water in oil( light grey and milky). with the discoloring does crank need replacing or just rod bearings? also with the water issure should I rebuild whole motor? what are the possible ways water got into crank to begin with head gasket? others?
2. 81 it 175 smokes bad! compression tests out good, tons of powere still. friend suggested running less oil in premix fig this a bad idea! top end rebuild?
3. 94 rm 250 sat for over a year before i bought it, needle seat/floats keep sticking even after dumping out all old gas and cleaned carb! black gummy substance! in tank?? petcock? how to clean out plastic tank b-12? diesel?
4.84 xr 200 ticking sound from head sounds like a v-8 misadjusted valve lash. no book! never been into this one with a wrench! do these have valves or lifters above piston?
5 not dirt bike but i'll try anyways, 00 yzf 600 ran fine till fuel line came off while riding, fixed line now won't start? has spark. crankcase had fuel smell when stuck nose to fill opening.
