I have tried to find out the theoretical consequenses of what will happen if I change to a 125 pipe on my 200. The reason I would like to try it is that the left portion of the 200 pipe really easy gets dented when I crash - and that happens :)
So far I have not been "enlightened" and I am getting more and more curious/confused by the answers I have got.
The general opinion is that I will lose low end and eventually gain top end.This makes me puzzled because in my understanding;
The exhaust pulse has to travel a certain distance back and forth in the pipe.
This distance/volume is changed if I for an example put a 125 pipe on my 200.
In this case the distance/volume decreases and the pulse travels faster back to the exhaust port.
So far so good, I can understand that changing this distance/volume will change the timing of the pulse and have effects on how well the pulse will help to fill the cylinder with fresh air/gas.
But how is it that this is changing over the rpm register???
How can this change in distance/volume alter the power characteristics in a certain range in the rpm spectrum?
My guess would have been that it would remain constant over all rpm´s!
Yes, I will also try to find a 125 pipe also to do a practical test, it will be very interesting to see if I will feel a difference at all???
