hey,
i found a place that listed the 1.60x21 excel rim as fitting my bike and the 91 kx500. it also used the oem spokes. they also listed the excel rim with the oversized spokes. so i think the one im looking at is right ( i hope). the forks i have are the 91 kx500 forks. i need a new rim cause the kx one i have is cracked. i have the forks, triple clamp, front brake and front brake line and wheel that im putting on. the rims are the same but the kx hub, brake rotor and axle are different than the kx. cya, gotta get to work
