hoosierf
325
I found a website that has some info on GG crossover parts, but I cannot find a part number for the pistons they reference. Anyone no which Weisco or vertex fits in a 2003 200?
Thanks for the help.
Offroadr
Ready to bang some trees!
Jan 4, 2000
5,227
25
I'd go to the Smackover motorsports website or call them, they should be able to help
Kokanee
189
I heard that a polaris snowmobile(wiesco) will fit the 200. also check the wassnor piston website I belive they also make GasGas pistons.
roostafish
165
A CR 250 piston bolts right in the 250. I have a Vertex Honda CR 250 piston in mine. Smackover Motorsports not only has them in stock, but will give you any info you may want if you're skeptical.
gas gas jack
48
wiseco piston
gas gas jack
48
try wiseco piston # 2365M06250; it's "normal" application is a 96-98 Polaris XCR600 special, and it was a limited run sled( aka-market failure!), so it's a little difficult to find this piston through normal parts suppliers. i strongly suggest a .3mm base gasket (part # ME25644009), as this will probably improve your bottom end throttle(sp?) response. i've lots of experience with this piston-works perfect! jack
Enduro_Nut
1,155
I use SMS - Brian is one of the most experienced GasGas dealers around. He took his club team to the ISDE this year and managed #1 for the US club teams. He is also an authorized RACETECH shop.
<SMSRACING.NET>
