mimake
Hello, I just pulled my yz 125 engine apart, I need to pull the crankshaft out. I split the case and the crank is still stuck on the other half, how do I get it out? I also need to know where can I get a good manual. Thanks for the help!
Backslayer
Go Big or Go Home
280
Service manuals from yamaha are your best bet. use a couple pieces of wood to set the case on high enough so that the crank has a little room to fall out. then take a rubber mallet or a hammer and a piece of wood and tap it out of there.
