TAZMAN
YZ 250 help, con-rod and clearance for a 1996
Can someone with a manual tell me the specs for the connecting rod to crankshaft thrust washer clearance? How much play up and down? Side to side? Also need the piston-cylinder clearances. Looks like I have a 68.0466 bore size. Should I use a .020 oversize piston? What should the ring gap be? Thanks for all the help!
