Purchased a 01 YZ426F recently and it didn't come with a manual so I need some information/help on a couple issues.
The seller told me he only put 4 to 5 hours on the bike so I'm guessing he never changed the oil and filter. When I removed the oil filter I was alarmed to see small metal chips/shavings in the filter. Would this be normal for the 1st oil change? If this wasn't it's 1st oil change is it normal to find metal in the filter?
When draining the oil from the frame I also noticed there was a drain plug on the bottom of the motor, I drained it from this location also, was this correct?
Last question, how much oil is required when the filter is replaced?
