DR4Ztrokes
- Aug 16, 2001
- 19
- 0
I need to dial in my sons kx-100 jetting. It is completely stock with keihnin carb originally equipped with 138 main. With that jet there was significant splooge (enough to help lube chain!) and smoke. The plug was black/wet but never enough to cause problem with bike starting or running. I have since gone to 135 and the 132 jets and let out the air/fuel setting with less but still considerable splooge and smoke. Plug is about the same but bike seems to be reving out better. Should I just keep going to smaller main jets to iron this out or should I be doing the clip and other adjustments in conjunction with this? He is not a full out rider, bike is used more for trails and noncompeting laps at motox tracks. In northeast weather and ride below 3000ft. Riding a 4stoke I've been out of this type thing for several years, while it is not changed much my frustration level does seem higher! Appreciate any help.
