A couple of quick questions. I just cleaned and reassembled my power valve and installed new rings, both for the first time. Upon setting the shaft that runs from the clutch case to the KIPS valve gear I was trying to decide if the shaft needed to be set with "preloaded" and when I turned it I apparently gave it too much and broke the piece on the clutch end of the shaft( attaches with 2 small allen bolts to the shaft and has a pin that rides in the "advancer") :eek: . First, since I obviously don't have a clue what the technical terms are :think: ....what is the piece that broke called? When I reassemble everything, I assume it requires to be turned slightly, providing tension that returns the valves to closed position...is that correct?? Can someone describe the correct procedure/setting please. Also, I am looking for black or green side plates as well I want to change my radiator shrouds to green ( I have a '96, 'nuff said) do KX rear fenders fit with modification or is it best to order an MX fender from Fredetts. Thanks.
