I was thinking about machining a "hybrid" needle at work on the lathe. I have plenty of time, and I need to learn the machine (lathe that is) anyways. I have been having trouble with plugs fouling. Now granted.. I have come a long way mainly because of what I've read in here over the last two years. I've went from fouling about two an hour to two a day. Still learning. Compression is good, seals are replaced, float height's set, and all of that good stuff. I am fouling while averaging 1/2-full throttle. I took all of the measurements on my current needle to get a feel of it. It looks like it has 5mm of adjustment...(each groove being 1mm). I know a needle is only about 30.00, but I am basically just playing, and trying to learn. I know the taper rate. I wonder if I could make a needle and at the top attache a small collar with an even smaller set screw. And with this.... maybe get 10mm of adjustment....does it need to be a softer metal so that the seat does not wear? Or a harder metal so that the seat wears to it?
