Check out the new user map ... gives a representation of where all the users on the site at any given time are located.
Before anyone thinks "privacy", rest assured there are no privacy violations, and no personal info used to populate the map. It's NOT a "Member Map, it's a "User Map". Which means, it only uses the ISP assigned IP addy to put pins on the map. We aren't drawing any location info from your profile, even if you provided it.
Also be aware, in most cases the pin won't be precisely located, it drops where your ISP says the IP is (typically, city/town center), not necessarily where you think it is :OHYEAH:
http://dirtrider.net/forums3/members/usermap
