newer pump seal, new oil, and gear oil still turns white
bill kdx nj
8
I have a newer water pump seal in the engine and change the gear oil consistantly, but it somehow turns white cloudy color after a few short rides.
I switch between 10w30 , 40 and 15w40 and a shot of Lucas oil depending on weather condtions throughout the year.
Why does it turn milky color? could the gear breather hose hanging suck water in during water crossings?
d rockwell
82
Water in trans oil.....
The water pump has an inboard bearing that is pressed into the right side case half and should be replaced when the new bearing and seal are pressed on the shaft. Plus, properly pressing the new bearing and seal on the impeller shaft determines it's life......
SVandal
201
Another possibility is that the shaft is grooved and lets water leak past. On mine I replaced the 2 seals, bearing, and shaft because the seals and shaft were bad and I was in the area so the bearing was changed as well. With an 89 there may be only one seal. Either way, did you check the water pump shaft for problems when you replaced the seal?
Another option is the breather tube, or worst case is a leak/crack in the water jacket.
